habe gelesen das in UK Nitron Stoßdämpfer ziemlich
gefragt sind.
Hier ein paar Daten:
Compact, low pressure design
Suitable for use with 2.25" internal diameter springs
Anodised aluminium adjuster knob, threaded sleeve, top cap, spring platforms
Single adjustment knob adjusts bump and rebound simultaneously
Induction hardened chromium plated piston rod
Motorcross derived 'quad-ring' low friction sealing system
Motorcross derived piston rod scraper system to protect seals
Teflon lined stainless steel Aurora aerospace spec. spherical bearings
Low profile bonded bushes as an option for the end eyes
Any alternative end fittings (full CAD/CAM service available)
Fully re-buildable and re-valvable
Steel body with rust proof aluminium threaded sleeve
No-slip motorsport spring seat adjustment system using holes instead of castellations
Internal nylon 66 rebound stop
Progressive cellular bump stop
Units can run be inverted if requested
Ein Dämpfer mit Federn wiegt 1,25kg
und ein Set für die Elli kostet 850 Pfund.
Ist ja wohl DIE Konkurrenz zum Technoflex/Wilbers
Weitere Infos findet ihr unter www.nitron.co.uk
Gruß Michi😇
