Hinweis:
1 = offizieller Recall
2 = "bei der nächsten Befassung mit dem Fahrzeug"
3 = zur Info
2010-10 - 2 - Wrong Downpipes, Catalysts fitted (supercharged cars)
2010-09 - 2 - Accusump Oetiker Clips (Accusump-equipped cars)
2010-08 - 3 - Engine Calibration Files (Toyota-engined cars)
2010-07 - 3 - New Inspection Schedules (small plattform)
2010-05 - 3 - Elise MY11 Introduction (Elise)
[url="http://www.elisecommunity.de/download/ServiceBulletins/2010-04.pdf"]2010-04 - 3 - New MLS Head Gasket (Rover engined-cars)
2010-03 - 3 - AC Drain Tubes (Evora)
2010-02 - 3 - Exhaust Silicone Mountings (Evora)
2010-01 - 2 - Siren and CDL fuse (Evora)
2009-R1 - 1 - Rear Hub Securing Bolts (see VIN list)
2009-R1 - 1 - Rear Hub Securing Bolts (see VIN list) - revised edition
2009-18 - 3 - Updated ECU Program (Evora)
2009-17 - 3 - Retrofitment of ISOFIX Brackets (Evora 2+2)
2009-16 - 3 - Door Latch Issues (Evora)
2009-15 - 3 - Water Ingress Attention Areas (Evora)
2009-14 - 3 - Special Lubricant for Door Lock Button (Elise, Exige, Europa)
2009-13 - 3 - Additional Drain Hole in Door Shell (Evora)
2009-12 - 3 - Fitment of diffuser finisher heatshield (Evora)
2009-11 - 2 - Torque check of rear suspension bolts (Evora)
2009-10 - 3 - Introduction of Limited Edition Exige Scura
2009-09 - 2 - Uprating CDL-Alarm Fuse (Evora)
2009-08 - 3 - Front Access Hatch vs. Wiper Motor (Evora)
2009-07 - 3 - Gearlever Knob Security (Evora)
2009-06 - 3 - Steering Column Spacer Tool (Evora)
2009-05 - 3 - Condenser Pipes Dowty Washer (Evora)
2009-04 - 3 - ABS (Elise,Exige - from MY08)
2009-03 - 2 - Horn Relay (Exige Cup 260)
2009-02 - 2 - Rear Hub Securing Bolts (see VIN list)
2009-01 - 3 - Race Precautions (Elise, Exige, Europa)
2008-17 - 3 - Introduction of '09 M.Y. Exige Cup 260
2008-16 - 3 - Introduction of Europa SE (Special Equipment)
2008-15 - 3 - Revised clip to secure door latch release rod (Elise, Exige, Europa)
2008-14 - 2 - Weathersealing of windscreen lower edge (Europa S)
2008-13 - 2 - Inspection of oil cooler sandwich plate (Elise, Exige, 2-Eleven)
2008-12 - 2 - Update of instrument pack calibration (MY08 Elise, MY08 Exige)
2008-11 - 3 - Adjustment of early type mirrors (2-Eleven)
2008-10 - 3 - Precautions regarding fitment of Accusump one-way valve (all models)
2008-09 - 3 - Fitment of revised camber shim plates (Elise, Exige, Europa)
2008-08 - 3 - Radiator hose security (Elise, Exige, Europa)
2008-07 - 3 - Precautions when re-fitting exhaust muffler (all models)
2008-06 - 3 - Advice regarding paint protection (2-Eleven)
2008-05 - 3 - Introduction of Fully Type Approved Lotus Sport Exige Cup 260
2008-04 - 3 - Precautions when connecting oil coolers (2-Eleven)
2008-03 - 2 - Retrofitment of roof scoop intake grille (Exige S 240)
2008-02 - 2 - Rework of early build Lotus 2-Eleven (2-Eleven)
2008-01 - 3 - Introduction of Elise SC (SuperCharged)
2007-16 - 3 - Introduction of MY08 Elise and Exige
2007-15 - 3 - Introduction of Lotus 2-Eleven
2007-14 - 3 - Possible cause of continuous cooling fan operation (Elise, Exige)
2007-13 - 3 - Service replacement blower motor resistor pack kit A120P0148S (Elise, Exige)
2007-12 - 3 - Supercharger mounting bolt precautions (Exige S)
2007-11 - 2 - Radiator hose security check (Elise, Exige)
2007-10 - 3 - Routing of purge valve harness (Elise S)
2007-09 - 3 - Supercharger gas sealing (Exige S)
2007-08 - 2 - Supercharged Exige S stalling on coast down (Exige S USA)
2007-07 - 2 - Revised engine programme for MY06 USA (USA Elise, USA Exige)
2007-06 - 3 - Track use precautions (all models)II - all models
2007-05 - 2 - Addition of drain holes to HVAC chamber floor (Elise, Exige)
2007-04 - 3 - Introduction of Lotus Sport Exige Cup 255
2007-03 - 3 - Introduction of Lotus Sport Exige S British GT Special Edition
2007-02 - 3 - Monitoring of battery charge state on vehicles in storage (all models)
2007-01 - 3 . Introduction of low speed damage mitigation features (USA Elise, USA Exige)
2006-R1 - 1 - USA - Fitment of modified gear lever (Elise USA)
2006-R1 - 1 - ROW - Fitment of modified gear lever (Elise 6-speed, Exige 6-speed)
2006-33 - 3 - Service replacement of sill routed AC pipes (Elise, Exige)
2006-32 - 3 - Repair of gas strut anchorage to tailgate (Exige)
2006-31 - 3 - Mass Air Flow sensor orientation (Europa)
2006-30 - 2 - Stop lamp switch adjustment check (Europa)
2006-29 - 2 - Check of water hose 'T'-piece connection (Europa)
2006-28 - 2 - Addition of drain holes to clamshell reinforcement panels (Elise)
2006-27 - 2 - Threadlock check of ball joint plinth fixing bolts (Elise, Exige Europa)
2006-26 - 2 - Reinforcement of chargecooler air ducts (Exige S)
2006-25 - 3 - Lotus Scan 3 update disc (all models)
2006-24 - 2 - Clearance of washer bottle to gearchange mechanism (Europa)
2006-23 - 3 - Introduction of Europa S
2006-22 - 3 - Introduction of revised adjustable anti-roll bar for Super Sport option (Elise, Exige)
2006-21 - 3 - Ball joint plinth security (Elise, Exige, Europa)
2006-20 - 3 - Momentary engine power interruption (MY06 cars with AC)
2006-19 - 3 - Rear suspension toe-link torque check (Elise, Exige)
2006-18 - 3 - Coolant additive precautions (all models)
2006-17 - 3 - USA - Retrofitment of MY06 LED type rear lamps (USA Elise, USA Exige)
2006-17 - 3 - ROW - Retrofitment of MY06 LED type rear lamps (Elise, Exige)
2006-16 - 3 - USA - Introduction of MY07 Elise for USA market
2006-16 - 3 - ROW - Introduction of MY07 Elise and Exige and new model Elise S
2006-15 - 3 - Triggering of alarm by rain water movement (Elise, Exige)
2006-14 - 3 - USA - AM Radio interference from LED brake lamps (Elise USA, Exige USA)
2006-14 - 3 - AM Radio interference from LED brake lamps (Elise, Exige)
2006-12 - 3 - Oil cooler hose check (Elise, Exige)
2006-11 - 3 - Service inspection of road spring seats and caps (Elise S2)
2006-10 - 2 - Contamination of throttle body with assembly lubricant (MY06 Elise, MY06 Exige)
2006-09 - 3 - Approval of Dunlop 9090 tyres (Esprit V8)
2006-08 - 2 - Rectification of sticking door release button (Elise, Exige)
2006-07 - 2 - USA - Updated ECU programmes and Service Schedules (USA Elise, USA Exige)
2006-07 - 2 - ROW - Updated ECU programmes and Service Schedules (Elise, Exige)
2006-06 - 3 - Water infiltration of rear luggage compartment (Elise S2)
2006-05 - 3 - USA - Introduction of Exige S for USA market
2006-05 - 3 - Introduction of Exige S
2006-04 - 3 - Approval of Yokohama C.drive tyres (Elise S1)
2006-03 - 3 - USA - Introduction of 'Track Pack' option (Elise USA, Exige USA)
2006-03 - 3 - Introduction of 'Super Sport' suspension option (MY06 Elise, MY06 Exige)
2006-02 - 2 - Airbag system temperature operating range (Elise USA)
2006-01 - 3 - Introduction of MY06 Exige Cup 190 & 240
2005-20 - 3 - Lotus Scan 3 Update for MY06 (all models)
2005-19 - 2 - Inspection and rectification of hose routing in engine bay (Non-USA Elise, Exige)
2005-18 - 2 - Precautionary treatment of sharp edges beneath fascia (Elise, Exige)
2005-17 - 3 - Introduction MY06 USA and CDN
2005-16 - 3 - Introduction MY06
2005-15 - 3 - Approval of Yokohama AD07 (Elise)
2005-14 - 3 - New Transmission Options LTC,LSD (Elise USA)
2005-13 - 3 - Introduction of revised gear ratios for standard Elise model (Elise)
2005-12 - 3 - Rough Road Sensor fault codes (Esprit V8)
2005-11 - 2 - Toe-link locknut check (Elise, Exige)
2005-10 - 2 - Security of insulated soft top lining (Elise)
2005-09 - 2 - Pipe routing and damage inspection (all models)
2005-08 - 3 - Driver's seat runner fixing positions (Elise)
2005-07 - 3 - Squeaks and rattles from hard top roof (Elise, Exige)
2005-06 - 3 - Introduction of Limited Edition Lotus Sport Exige 240R
2005-05 - 3 - USA - Oil cooler fitment change (Elise USA)
2005-05 - 3 - ROW - Oil cooler fitment change (Elise, Exige)
2005-04 - 3 - New features of 'Performance Pack' and 'Lightweight' options (Elise, Exige)
2005-03 - 2 - Lotus Scan 3 (USA) installation disc (Elise USA)
2005-02 - 3 - Introduction of new sump joint sealant (Elise 5-speed)
2005-01 - 2 - Optimum position of AC temperature probe (Elise)
2004-29 - 3 - Orientation of engine earth braid (Rover-Elise)
2004-28 - 2 - Rev Limiter Acitivation (111R, ExigeS2)
2004-27 - 2 - Water Ingress Sunvisors (111R)
2004-26 - 3 - Precautions fault codes P1491/P1493 (EliseS2 111, EliseS2 111S)
2004-25 - 3 - Retrofitment driving lamps (EliseS2)
2004-24 - 3 - Dealer-Fit 4-point harness (ExigeS2)
2004-23 - 3 - Turbocharger Wastegate Checking (Esprit V8)
2004-22 - 2 - Wiring Harness Retention (111R,ExigeS2)
2004-21d - 3 - Oil Cooler Hose Check (Elise USA)
2004-20d - 3 - Tyre Recommendation (early Esprit Turbo)
2004-19d - 3 - ScanIII Installation Disc
2004-18d - 2 - Sticking Gearlever Lift Tube (...)
2004-17d - 3 - Suspension Settings (Esprit FE)
2004-16d - 2 - Water Shielding Heater Flaps (Elise)
2004-15d - 2 - Relocation Tyre Inflator (ExigeS2)
2004-14d - 2 - Footwell Corrosion (Elise)
2004-13d - 2 - Rear Aerofoil Fixings (ExigeS2)
2004-12d - 2 - Subframe Edge Finisher (111R, ExigeS2)
2004-11d - 3 - Throttle Setting Procedure (111R, ExigeS2)
2004-10d - 2 - Fuel Pipe Routing (111R, ExigeS2)
2004-09d - 3 - Revision Maintenance Schedule (Elise, ExigeS2)
2004-08d - 3 - Revised Balljoint Plinth Fixings (Elise, ExigeS2)
2004-07d - 3 - Water Ingress Areas (Elise)
2004-06d - 2 - Clarification TPS (Elise 111R, Exige S2)
2004-05 - 3 - Introduction Elise 111R, Exige S2[/url]
2004-04d - 2 - Fuel Tank Bay Underpanel Edge Protection (Elise 111R)
2004-03d - 3 - Introduction revised front turn lamps (Elise)
2004-02d - 3 - Release Agent Smoke (Elise 111R)
2004-01d - 2 - Fixierung Schaltseilzugschutztüllen (Elise 111R)
2003-16 - 3 - Spannschraube Nockenwellenantrieb (Esprit V8)
2003-15 - 3 - Lead-free brake pads (Elise)
2003-14 - 3 - Availability Upgrade Kit (Elise S1 S160)
2003-13 - 2 - Water Pipe Chafe Damage Check (Elise)
2003-12 - 3 - Suspension Enhancement Kit (Elise S1)
2003-11 - 3 - Toe-Link Fine Pitch Balljoints (Elise)
2003-10 - 3 - Introduction Esprit MY04
2003-09 - 2 - Front Indicator Lamp Retention (EliseS2)
2003-08 - 3 - Introduction Elise Sport111
2003-07 - 3 - Introduction MY04 Elise
2003-06 - 3 - Introduction Elise Sport 135R
2003-05 - 2 - Turbo Inlet Trunking Sleeve (Esprit V8)
2003-04 - 3 - Introduction Lock and Softtop Products (all)
2003-03 - 3 - Revised Service Schedule (EliseS1)
2003-02 - 3 - Revised Service Schedule (EliseS2)
2003-01 - 2 - Engine Harness Security Check (Exige AC)
2002-R2 - 1 - ECM Reprogramming, Brake Lines Check (340R, Exige)
2002-R1 - 1 - Brake Caliper Check (Elise S2)
2002-25d - 3 - Wassereintritt Gep„ckabteil (Elise S2)
2002-24d - 3 - Klappern Trschnapper (Elise S2)
2002-23d - 3 - Radioentstörkit (Elise 2)
2002-22d - 3 - Shurlock Instruments (Elise S2)
2002-21d - 2 - Inspektion Lenks„ulen-Kreuzgelenk (Esprit MY02)
2002-20d - 3 - Umluftkappe-Ablenkblech (Elise S2 AC)
2002-19d - 3 - Tankstutzendichtung (Elan M100)
2002-18d - 2 - Oil Cooler Hoses (all cars)
2002-17d - 3 - Retro-Fit Hardtop (Elise S2)
2002-16 - 2 - Brake Pipe Inspection (all cars)
2002-15 - 3 - Synthetic Engine Oil (Esprit V8)
2002-14 - 3 - Auxiliary Belt Tension (Elise)
2002-13 - 3 - Introduction MY02 Elise 111, 111S
2002-12d - 3 - Geänderter Wartungsplan (Elise S2)
2002-12 - 3 - Revised Maintenance Schedule (Elise S2)
2002-11d - 3 - OAT-Kühlmittel (Elise S2)
2002-10d - 3 - Hardtop, shortened SoftTop (Elise S2)
2002-10 - 3 - Hardtop, shortened SoftTop (Elise S2)
2002-09d - 3 - Ölfiltermontage (Esprit V8)
2002-08d - 3 - Scan II Tester (Elise)
2002-07d - 2 -Querlenker-Kugelgelenke (Elise)
2002-06 - 3 - Battery Recommendation (EliseS2)
2002-05 - 3 - Misfire Learns (EliseS2, EspritMY02)
2002-04 - 3 - Cobra 8185 Alarm (Elise S2)
2002-03 - 3 - AirCon Option (Elise S2 AC)
2002-02d - 3 - Introduction Elise Sport135
2002-02 - 3 - Introduction Elise Sport135
2002-01d - 3 - Introduction MY02 Esprit
2002-01 - 3 - Introduction MY02 Esprit
2001-R3g - 1 - Steering Rack (Elise) -DE
2001-R2 - 1 - Fuel Filler Breather Pipe (Elise S1, Exige)
2001-R1 - 1 - Misfire Protection Kit (Elise 111S)
2001-08 - 3 - Brake Pads (Elise S1)
2001-07 - 2 - AC Compressor (Esprit V8 AC)
2001-06 - 3 - Rear Suspension Toelink (Elise S1, Elise S2)
2001-05dx - 2 - Fascia Blistering (Elise S2)
2001-05g - 2 - Fascia Blistering (Elise S2) -DE
2001-05 - 2 - Fascia Blistering (Elise S2)
2001-04 - 2 - Climate Controls (Elise S2)
2001-03 - 3 - Pantograph Arm (Esprit from MY98)
2001-02 - 3 - HT Lead Connections (Elise S1)
2001-01 - 2 - High Idle (Elise S160)
2000-R1 - 1 - ECM Electromagnetic Shield (Elise 111S)
2000-20 - 3 - HT Lead Connections (Exige, 340R)
2000-19 - 3 - Introduction Elise S2
2000-17 - 3 - Toe Link Ball Joints (Elise)
2000-16 - 3 - MMC Replacement (Elise)
2000-14 - 2 - Bulkhead Water Sealing (Exige)
2000-13 - 3 - Throttle Cable Adjustment (340R)
2000-12 - 3 - Cylinder Liner Sealant (Esprit)
2000-11 - 3 - Dunlop Tyres Approval (Esprit)
2000-10 - 3 - Aerial Ground Plane Foil Kit (Elise)
2000-09 - 3 - Introduction Exige
2000-08 - 2 - Rear Mudguards (340R)
2000-07 - 3 - Door Lock Barrel (Elise)
2000-06 - 3 - Battery Monitoring (Elise)
2000-05 - 3 - Service Schedule (Elise)
2000-04 - 3 - Bearing Guide Tube Sleeve (Esprit V8)
2000-03 - 3 - Introduction MY00 USA Esprit
2000-02 - 3 - Introduction Elise S160
2000-01 - 3 - Introduction 340R
1999-R1 - 1 - Fuel Pipe Joint Integrity (Elise)
1999-16 - 3 - Fuel Recommendations (all)
1999-15 - 2 - Coolant Hose Clips (Elise)
1999-14 - 2 - Ignition Coil Replacement (Elise 111S) - DE
1999-13 - 3 - Rear Brake Caliper Mounting (Elise)
1999-12 - 3 - Clutch Pedal Trunnion (Elise)
1999-11 - 3 - Cambelt Tensioning (EspritV8)
1999-10 - 2 - Oil Cooler Hose Heatshielding (Elise S190)
1999-09 - 2 - Steering Arms (Elise)
1999-08 - 3 - Door Window Frontguide Channel (Elise)
1999-06 - 3 - Rear ToeLink Balljoint (Elise)
1999-05 - 3 - Cylinderhead Fitting (Elise)
1999-04 - 3 - Alternator Heatshield (Elise)
1999-03 - 2 - Exhaust Downpipe Steady Bracket (Elise)
1999-02 - 3 - Introduction Elise111S
1999-01 - 3 - Introduction Esprit S350
1998-R1d - 1 - Rear ToeLinks (Elise)
1998-20 - 3 - Battery Recharging (Elise)
1998-19 - 3 - Coolant Header Tank Cap (Elise)
1998-18 - 3 - Coolant Header Tank (EspritV8)
1998-17 - 2 - Fuel Tank Breather System (EspritGT3)
1998-16d - 3 - Door Restraint Spring (Elise)
1998-15d - 3 - CylinderHead Core Plugs (Esprit V8)
1998-14 - 3 - Hall Sensor (Elan M100 Turbo)
1998-13 - 3 - MEMS 1.9 diagnostic card (Elise)
1998-12 - 3 - Service Schedule (Elan M100)
1998-11 - 3 - Low Usage Vehicles Electrics (Elise)
1998-10 - 3 - Clutch Release Adjustment (Elise)
1998-09d - 3 - Front Lower Wishbone Pivot Bush (Esprit)
1998-08d - 3 - Brake Judder Diagnosis (Esprit)
1998-07 - 2 - Service Schedule Non-USA (EspritV8)
1998-06 - 2 - Door Mirror Glass Adhesive (Esprit)
1998-05 - 3 - Rerouting Alternator Cables (Elise)
1998-04 - 3 - Cigarette Lighter Connection (Elise)
1998-03 - 3 - Fuel Recommendations (Elise)
1998-02 - 3 - Threadlocking Driver Seat Screws (Elise)
1998-01 - 3 - Front Brake Disc Shields (Elise)
1997-24 - 3 - Introduction MY98 Esprit
1997-23 - 3 - Cobra Security Alarm (Elise)
1997-22 - 2 - Refurbishment Alloy Wheels (all cars)
1997-20g - 2 - Engine Rework (EspritV8) -DE
1997-20a - 2 - Engine Rework Addendum (EspritV8)
1997-19 - 2 - Fuel Pump Fuse Uprating (Elise)
1997-18 - 2 - Water Hose Connections (Elise)
1997-17 - 3 - Clavis Gauge Usage on 4-Cyl-Engines (all)
1997-16 - 3 - Lockplate Turbocharger Flange (EspritV8)
1997-15 - 3 - Track Use Preparations (Elise)
1997-14 - 3 - Winter Tyres (Esprit)
1997-13 - 3 - Exhaust Manifold Heatshield (Elise)
1997-12 - 2 - Throttle Pedal Linkage Bracket (Elise)
1997-11 - 3 - Krytox Anti-Squeak Fuild (all cars)
1997-10 - 3 - Idle Speed (EspritV8)
1997-09 - 3 - Turbocharger Wastegate (EspritV8)
1997-08 - 3 - ECU Earth Connection (EspritV8)
1997-07 - 3 - Avoiding Windscreen Stress (Elise)
1997-06 - 3 - Uprated Starter Motor (Elise)
1997-05 - 3 - Door Window Upstops (Elise)
1997-04 - 2 - Steering Arm Bolts (Elise)
1997-03 - 3 - Working in Chassis Structure (Elise)
